Brake light trio
RE: Brake light trio
i know about the dealer visit, i'm just wondering if they are supposed to turn them selves off, as mine did. i started up the car and got traction failure and abs fault on the message center, started up again after getting gas and only got abs fault, and then once i got home i shut it off and started it up and the lights shut off like normal
all i know is i pulled some fuses out and now i got some bleeps and squeaks with abs fault traction failure flashing... SRS light went out Solution? LOOSE Connection under the passenger seat. It was confirmed by i great mechanic i use in fairfield CT. I keep asking people what is the best book to get for a Landrover (ie OEM Landrover Range Rover Service manual for the techs that work at landrover?)
Dublz
09-04-2007 08:31 AM
