Brake light trio
Old Dec 9, 2006 | 08:24 PM
esaycho's Avatar
Default Brake light trio
If the trio of brake lights come on in a range rover, will they reset themselves if the fault is no longer there, or does it require a trip to the dealer?
Old Dec 9, 2006 | 10:08 PM
Default RE: Brake light trio
It will require a mechanic with a test book or an AutoLogic scanner or one similiar to read and then clear the codes for your brakes.
Mike
Old Dec 10, 2006 | 05:29 PM
esaycho's Avatar
i know about the dealer visit, i'm just wondering if they are supposed to turn them selves off, as mine did. i started up the car and got traction failure and abs fault on the message center, started up again after getting gas and only got abs fault, and then once i got home i shut it off and started it up and the lights shut off like normal
Old Dec 11, 2006 | 10:30 PM
DaRovers's Avatar
all i know is i pulled some fuses out and now i got some bleeps and squeaks with abs fault traction failure flashing... SRS light went out Solution? LOOSE Connection under the passenger seat. It was confirmed by i great mechanic i use in fairfield CT. I keep asking people what is the best book to get for a Landrover (ie OEM Landrover Range Rover Service manual for the techs that work at landrover?)
Old Dec 11, 2006 | 11:05 PM
esaycho's Avatar
The lights are off now, i'm just wondering if they are supposed to turn themselves off, because i know in the Discovery they stay on until the dealer resets them. If they arn't supposed to turn themselves off, then i think i'm in for a new BECM
Old Dec 11, 2006 | 11:43 PM
Bait's Avatar
ORIGINAL: esaycho
That's correct. Only current faults turn the lights on.
Old Dec 12, 2006 | 09:44 PM
esaycho's Avatar
thank you
Disco Doc
Jan 10, 2008 01:17 PM
Dublz
Sep 4, 2007 08:31 AM
charcoal grey
Jun 30, 2007 01:15 AM
mowthat
Mar 8, 2007 07:36 PM
Aquaholic
Mar 6, 2007 06:55 PM
