broken rear wiper arm?
![Exclamation](https://landroverforums.com/forum/images/icons/icon4.gif)
Hi i managed to break my rear wiper arm. i pulled it down by hand and replaced the blade. when i turned it back on it wants to go the opposite way. will not go back o correct position. ideas? thanks also my passenger seat fuse keeps blowing all the time. what could it be?
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
Easiest thing I can think of is to take a volt/ohm meter and set it to volts and find which side of the fuse slot is hot. Then set the probe to the other side, set it to ohms on a high range, put the other probe to ground to and watch it while disconnecting things associated with the seat one at a time until the meter reads a sizable change (increase) in resistance. Using this method you should be able to isolate the short and identify the culprit.
hilltoppersx
09-22-2010 07:44 PM
