broken rear wiper arm?
Old Sep 13, 2012 | 08:03 PM
newguy98's Avatar
5th Gear
Exclamation broken rear wiper arm?
Hi i managed to break my rear wiper arm. i pulled it down by hand and replaced the blade. when i turned it back on it wants to go the opposite way. will not go back o correct position. ideas? thanks also my passenger seat fuse keeps blowing all the time. what could it be?
Old Sep 14, 2012 | 11:45 PM
newguy98's Avatar
5th Gear
well i figured it out. uhh but the fuse still blows all the time. so any help will be nice.
Old Sep 22, 2012 | 12:59 AM
Ringo's Avatar
A fuse blows because the circuit is drawing too much power. This could be a short in the motor or a bad connector in the circuit. Is the carpet on the passenger side damp? Does the fuse blow immediately or when you try to adjust the seat?
Old Sep 22, 2012 | 09:59 PM
newguy98's Avatar
5th Gear
no but i has been and yes it blows immediately when i install the fuse.
Old Sep 23, 2012 | 03:27 PM
Ringo's Avatar
Easiest thing I can think of is to take a volt/ohm meter and set it to volts and find which side of the fuse slot is hot. Then set the probe to the other side, set it to ohms on a high range, put the other probe to ground to and watch it while disconnecting things associated with the seat one at a time until the meter reads a sizable change (increase) in resistance. Using this method you should be able to isolate the short and identify the culprit.
Disco Mike
May 4, 2011 07:08 PM
hilltoppersx
Sep 22, 2010 07:44 PM
kpl1228
Dec 23, 2009 10:04 PM
jdelp
Feb 20, 2008 10:11 AM
AzCamel
Jun 24, 2005 03:22 AM
