buying a 01 RR SE
Old Oct 6, 2008 | 09:49 PM
texas79's Avatar
Default buying a 01 RR SE
Would anyone recommend buying a 2001 Range Rover SE with 78000 miles? Will it be exspensive to maintain. What kind of problems can I expect? Thanks for the info.
Old Oct 6, 2008 | 11:52 PM
LRScott's Avatar
Default RE: buying a 01 RR SE
The p38 as I recall had minor electrical issues that can usually be fixed with a screw driver and some ingenuity but, this link I sent you shows any "documented" problem you could possibly have. I doubt you'll experience all of those problems but, you can see that most are relatively easy to fix. http://www.rangerovers.net/newrremedies.htm
Old Nov 10, 2008 | 07:20 PM
ldivine's Avatar
Range Rovers are relatively expensive to maintain... especially when compared to other brands. A lot of the costs can be minimized with DIY operations but there are still major parts that can break (EAS system, engine, etc). Typical upkeep can range from nothing to a couple thousand just depending on what happens to go wrong. There are a number of potential electrical and mechanical problems. some are cheap to repair/replace and some are exceedingly expensive. The Rover is NOT a cheap car to maintain though.
wan
Nov 8, 2006 09:55 PM
steveo
Jun 6, 2005 03:03 PM
roverKing
Member Group And Special Buys
Mar 12, 2005 10:14 PM
Tote
Mar 4, 2005 10:34 PM
7tiger7
Dec 30, 2004 04:27 PM
