a/c water leaking inside driver foot well
Old Jul 12, 2010 | 02:37 PM
sickvehicle's Avatar
Default a/c water leaking inside driver foot well
ok so a/c was not working so i jump wired direct from the battery because its blazzin hot out and any way cabin cooled down but i notice water dripping from over top of the gas pedal uh oh confused: any input?
Old Jul 12, 2010 | 03:17 PM
Your a/c drains are clogged.
Old Jul 12, 2010 | 05:59 PM
Default a/c leaking inside
you were sure right...cleaned them on no more probs thanxs for the post
Old Jul 19, 2010 | 02:44 AM
Russian_Rover's Avatar
Default Me too!
I have had the same problem. Could you please tell me where I can locate the drains?
Cheers!
Old Jul 19, 2010 | 05:46 AM
wilson96rr's Avatar
Under the vehicle, right about even with where the gas pedal is. There are two. One on the passenger side also.
Old Jul 4, 2011 | 07:21 PM
Shawn Brooks's Avatar
Thanx for the advise will check my 2000 Rovie for the same problem!
Old Jul 10, 2011 | 12:59 AM
LRScott's Avatar
Although your configuration will force the A/C compressor clutch to engage, it will cause the compressor to be running constantly, which can cause the evaporator to become iced up, reduce air flow and damage the system. Just be careful.
Spike: 200k miles!!! WOW.
Old Jul 13, 2011 | 06:33 PM
atancreti's Avatar
I had the same problem. However when I got mad and pulled out all the carpet and sound proof stuff I noticed my drain line was disconnected!!! Mine is a little different because Its a disco 1...
Old Jul 15, 2011 | 11:56 PM
Ringo's Avatar
Thanks, I have this problem too and thought I had to start taking stuff apart under the center dash. Whew, this came just in time.
Old Jul 19, 2011 | 10:31 AM
dirklemond's Avatar
Hello I'm a little confused, Where are the drains located exactly? I've been having the same problem with my 97 RR SE. Thanks
