CAN ANYONE PLEASE SUGGEST THE SOLUTION TO MY PROBLEM 2003 RANGE OVER HEATING ISSUE?
Old Apr 10, 2008 | 04:16 PM
Savannah's Avatar
Default RE: CAN ANYONE PLEASE SUGGEST THE SOLUTION TO MY PROBLEM 2003 RANGE OVER HEATING ISSUE?
Hi DJones.
You still did not answer my question.When the guage hits the red and you switch the ignition off and immediatly on again,does it read normal?If it does,we all should know that no engine can cool down from overheat to normal in ten seconds.Your problem is then electrical.
Regards
Marius.[&:]
Old Apr 10, 2008 | 04:19 PM
djones70's Avatar
yes it goes back to normal.Whats crazy is i had the compression test done and it came back fine.They did a chemical test on the block and it came back neg.i replaced everything except the water pump.What you think?
Old Apr 10, 2008 | 05:21 PM
WolfPack's Avatar
engine coolant temperature SENDER. it's cheap..do it.
And probably the ECT sensor itself while youre at it..cheap as well.
Old Apr 10, 2008 | 09:45 PM
roverguy7's Avatar
first of all, there is no ect sender on this engine, the ect is a duel sensor, however you do have a secondary sensor, your radiator outlet temp. i have seen a few problems with the wiring to this sensor getting shorted out on the a/c lines off the comp and causing all kind of erratic readings. generally it will throw a few fault codes. do you have any? but if youre not actually overheating, and it doesnt sound like you are, check the wiring at the lower right hand side of the engine and make sure its in tact and secured.
[/align]
Old Apr 11, 2008 | 12:25 PM
mom2bekah's Avatar
4wd High
I had a similar problem on ny 2000 rr. It turned out to be a relay in the engine compartment fuse box (fan wasn't cutting on) $10 fix Worth checking. The yellow relay was really brown.
Old Apr 11, 2008 | 12:27 PM
djones70's Avatar
the fan is operating.they found combustion gases in the expansion tank.
Old Apr 11, 2008 | 12:38 PM
djones70's Avatar
they did a chemical test and it failed.combustion gases in the system.they also did a laser check and the temp seems to be really high.therfore,it a cooling issue and not a sensor.I wish it was though.
olegit
Freelander
Jun 30, 2015 07:39 AM
TonyRover
Sep 19, 2013 02:06 PM
ngarover
Sep 2, 2013 03:09 PM
Scharfire
Jul 23, 2012 05:30 PM
HarCoTz
May 26, 2012 07:42 PM
