Can anyone tell me what this is
Old Nov 8, 2009 | 12:23 PM
snugg's Avatar
Default Can anyone tell me what this is
what is a rubber plug? looks like it's under the transmission. Green fuild it leaking from it. help please
Old Nov 8, 2009 | 05:21 PM
LRScott's Avatar
Its kind of hard to make out. Looks like a peep hole, maybe (mine has something of this sort but its metal, and my other car its plastic). Anyhow, that green stuff is probably coolant, although it should be orange dexcool not green oat (check your coolant resivour and tell us what color it is). The coolant is most likely leaking from somewhere above the transmission and then leaking down the side of it. Check your hoses for any signs of leaks.
Old Nov 8, 2009 | 07:26 PM
snugg's Avatar
The coolant is blue on the 2005 models. Could the transmission be leaking? It is suppose to be a sealed unit. I read on the net the transmission fluid is green.
Old Nov 8, 2009 | 11:36 PM
LRScott's Avatar
What a weird color combination... You are right, coolant is blue, and transmission fluid is green. Which means your transmission is leaking . Take some more pictures, that one you posted is very blurry. Although, the sticker underneath it says "filled for life" many owners have found benefits by flushing it with new ATF.http://www.rangerovers.net/maintenan...nyservice.html
Old Nov 9, 2009 | 04:02 PM
snugg's Avatar
I took it to the dealer as I was close to the 90,000 mile service. Dealer told me it was a leaking manifold(or near that location). i should be picking it up tomorrow so i'll have more info to post an up date.
Old Nov 10, 2009 | 10:19 AM
snugg's Avatar
I found this pic from a post on another site. I think land rover is making their own coolant and not using the bmw blue. The green color for the transmission fluid is not the color of the fluid but the type plate that uses ESSO LT 71141.
Attached Thumbnails Can anyone tell me what this is-atf%2520amber%252c%2520coolant%2520green%5B1%5D.jpg
File Type: pdf
Childeric
Apr 4, 2014 12:13 AM
disc oh no
Oct 19, 2011 10:24 PM
loosescrew
Dec 5, 2008 06:12 PM
rosalind
Aug 7, 2007 09:26 PM
