Can I place a 4.6 crank in a 4.0 block?
Old Mar 4, 2011 | 05:48 PM
Mikedag's Avatar
Default Can I place a 4.6 crank in a 4.0 block?
Hope I'm in the right forum....
Any chance of rebuilding a 4.0 block with a 4.6 crank and connecting rods? I understand the engine ecu will need to be swapped to a 4.6 version.
Old Mar 6, 2011 | 01:03 AM
LRScott's Avatar
The ecu does not need to be swapped. The becm needs to be reconfigured for a 4.6 engine. Which is a simple as checking a box on a computer. Granted you have that computer... The swap should work. BTW, what year of rover do you have? It makes a difference. From what I've found, the bosch blocks are not the same as gems.
Old Mar 7, 2011 | 10:39 AM
Mikedag's Avatar
Default My 1999 RR - Bosch
1999 Bosch RR but I may have a GEMS 4.0 from a 1996 Disco as the rebuild candidate.
Old Mar 8, 2011 | 09:11 PM
skyguy's Avatar
I have a friend that is a Rover Mechanic and he swapped the crank to one from a 4.6 in his 4.0 and he says it feels more powerful.
humroot
Jul 22, 2019 06:33 PM
1999rover
Feb 17, 2014 01:41 PM
GROVERDISCO
Dec 22, 2012 06:44 PM
mouse
May 18, 2012 12:25 AM
JBEGIN
Jun 27, 2009 12:38 PM
