Changing airbags on 2001 RR HSE
Old Jun 24, 2007 | 01:28 PM
wrangler04's Avatar
Default Changing airbags on 2001 RR HSE
I had a question on how long it takes to change the front and rear bags on a 01 HSE RR. I dont have a lift just 4 jack stands and 2 floor jacks. Any special tools needed or any tips on how to do the job faster.
Thanks
James
Old Jun 24, 2007 | 07:07 PM
Default RE: Changing airbags on 2001 RR HSE
Why are you replacimg the bags?
Mike
Old Jun 25, 2007 | 11:46 AM
wrangler04's Avatar
Cause they leak, rotted out. I can get a set for $600. The RR isnt mine Im looking at doing this for my buddy the dealership wanted like $2k. So any help here or what?
Old Jul 1, 2007 | 02:05 PM
wease206's Avatar
95-2002 rr always have air problem the EAS why dont you jyst change it to coil and never have that problem again
Old Jul 19, 2007 | 09:31 PM
tim's Avatar
tim
To change my front bags, I raised the body using a hyd jack located just to the rear of the front wheel where the tube frame begins to bend upwards. Once the body was quite high, I then used the RR supplied jack and located it under the front axle near the side I would be working on. I used that jack to raise the axle up just a few inches to be able to remove the wheel / tire. In this configuration, you can then bleed off the air to the bag and nothing will move. Then, just change the bag. Each front bag took me about 30-45 minutes.
Never had to do the rears yet !
kevinb91
Oct 21, 2011 10:55 PM
VegasBD
15
Mar 3, 2010 11:20 AM
75stroppe
May 25, 2007 03:39 PM
freerider712
Jul 12, 2006 11:43 AM
95DISCO
Jun 6, 2005 06:08 PM
