Classic Transmission and Transfer case question
Old Feb 17, 2009 | 05:40 AM
xb70valkarye's Avatar
Default Classic Transmission and Transfer case question
I test drove a '91 Classic yesterday and was surprised to see that there was no diff lock like the Series I Disco has. Is it the same transfer case? If not can you put a Disco I transfer case in there?
second question is the Transmission itself. What is in there? Can you swap it with a Transmission from a Disco 1 in there?
I have a Series II disco but am interested in owning a Classic Range Rover too and was just curious since I have access to a parts 1996 Disco 1 too.
thanks
Fred
Old Feb 17, 2009 | 04:20 PM
I see no reason to replace the tranny, as for the t/case, you currently have a Borg Warrner t/case with a viscus coupling, a LT 230 t/case will bolt in with a few changes, such as a new drive shaft, linkage and mounts.
I have a friend who specializes in Classic, shout if you want to get in touch with him.
Old Feb 18, 2009 | 04:09 AM
How robust is the BW t-case compare to the LT-230? One thing I like about the LT-230 is the ability to drive in low range on dry pavement with the diff-lock unlocked. Can the BW unit do this?
There is also another Classic Rover with a bad trans for sale and that is why I was wondering if a series 1 disco t-case would fit the Classic.
Thanks,
Fred
Old Feb 18, 2009 | 09:19 AM
Why would you want to drive in low range on the pavement, you are just burning up your viscus coupler.
The LT 230 is a much stronger t/c and was used in all the Discoverys.
Old Feb 19, 2009 | 02:35 AM
How about the trans swap? Did they use the same trans?
Low range in dry pavement has been useful for me backing my boat uphill into a curvy driveway. Its pretty steep and in low range there seems to be a lot less stress on everything.
How exactly does a viscus coupler work?
Thanks again,
Fred
doxster22
Jun 21, 2013 11:23 AM
seamonkey1
Mar 30, 2011 05:02 PM
xb70valkarye
Sep 9, 2009 04:46 PM
Paul Grant
Jan 2, 2009 06:10 PM
disco12
Mar 6, 2006 05:02 AM
