Climate control help needed
99 4.0S A/C blows cold only when it wants to. Just started checking things out. The outdoor temp. sensor seems to be working fine. The cabin temp sensor, well no way to really verify it but the air over assist fan in the sensor is running. Haven’t verified the solar gain or heater matrix sensors yet (still waiting on the service manual). Here’s what I have discovered. The floor, fascia and windshield program buttons work correctly however the floor/fascia and floor windshield program buttons are working backwards. i.e. the floor always gets air but the windshield position comes out of the fascia and the fascia position sends air to the windshield. Confused? It is. Any body have experience with the control system on this? Thanks in advance!
RE: Climate control help needed
OH Ya , I've seen plenty.and I hate to tell ya this but there is no way you'll figure it out without the help of a Test Book. your climate control head shows an open book at the RS indicating a fault. this system was built to keep the dealers service dept buisy.and it usually gets expensive.
Several sensors can be at fault, coolant sensor, evaporator,condenser etc. and most cars with vent direction problems have multiple issues.
If the compressor only cycles or runs intermitently and the book mark is not on. just check for a proper freon charge. A yellow sticker under the hood has the correct amount for your car, have your mechanic evacuate and recharge with the correct amount and see if that helps
Green Blood
12-22-2018 04:40 PM
dgreen78
10-06-2013 09:44 AM
