clunking noise when doing reverse...
Old Oct 3, 2006 | 07:40 AM
tobob1's Avatar
5th Gear
Default clunking noise when doing reverse...
i have a 97 4.0 se and sometimes when i put it on reverse i hear a "clunk noise" ,, and also when im driving it on cruise and hit the brake it feels like there's no power even when i floor the gas pedal, it feels like the auto transmission is not down shifting .....,,,
Old Oct 3, 2006 | 09:07 AM
CronicJoeBlunt's Avatar
Default RE: clunking noise when doing reverse...
Have you tired to manually down shift it? If your tourqe converter is going out it could make noises and you will loose fuild pressure which would effect the transmission. My 95 40 SE's converter locked up and the shaft from the tranny stripped out the converter which broke my flywheel, it made a BIG bang and then I was stuck. Before it went I noticed a vibration just before it would shift into 2nd.
Old Oct 3, 2006 | 11:37 AM
ORIGINAL: tobob1
I think you have 2 issues going on. Rovers are know to have a little slop in the power train and will klunk between drive and reverse. You can help it a little by having the slip joints on both drive shafts lubed, do your U-joint while under there.
As for the lack of power, do you ever seen a check engine light on?
As already mentioned try down shifting manually and see if there is a change.
How long has it been since you serviced the Tranny?
Mike
CoastieDisco2
Dec 2, 2012 09:37 AM
jtm964
Freelander
Sep 20, 2008 03:01 AM
LandRoverDiscoDos
Jun 16, 2007 02:15 AM
bonedoc
Jun 1, 2007 12:26 PM
trangle23
Nov 20, 2006 12:39 PM
