Coolant leak on RR country
Old Jul 23, 2006 | 04:00 PM
panamajack's Avatar
Default Coolant leak on RR country
I have a 93 RR Country that seems to be leaking from the top back of the engine..it runs down the trany and burns off on the catalitic converter or mufler pipe on the driver side. I do not see any moisture on the heater hoses so am i safe to assume that its not the core or a leaky heater hose? Is there any place for coolant coolant to leak between the intake manafold and the block? there is no "spray" on the fire wall or up behind where the heater hoses go in. Also dont hear any hissing or obvious running other than down the side od the trans/engine block coming from the top where its not accessible...It also only leaks under HOT (I'm assuming high pressure) conditions, once the car cools leak stops. Also no moisture in the cab itself...
Old Jul 23, 2006 | 05:12 PM
Default RE: Coolant leak on RR country
See my PM reply to you.
Mike
Old Nov 15, 2006 | 04:18 AM
givrdad's Avatar
I assume you already had this fixed, but just in case. . . Mine had to have the intake manifold gasket replaced to stop that leak.
Old Nov 15, 2006 | 03:26 PM
geoman's Avatar
Also check the throttle body heater plate on the underside of the intake plenum (drivers side). They leak, and the coolant can end up dripping down the back of the engine if the gasket is leaking on the back side.
regards,
Geoman
www.eurotekapg.com
1991 Range Rover Classic
ZMonet
Jun 24, 2016 04:00 PM
jtysoe
Sep 19, 2006 04:35 PM
irguy
Nov 2, 2005 12:45 AM
andrewsreef
Sep 28, 2005 08:06 PM
modyfyit
ROAMING WITH FRIENDS
Sep 28, 2005 02:44 AM
