Cooling system
Old Feb 6, 2007 | 10:40 PM
esaycho's Avatar
Default Cooling system
My rover doesn't get up to full operating temperature with the temps we have been having in ohio lately. Would it be ok to block off some of the radiator with card board to try and raise temperatures. The reason i ask is i think the blower motor is frozen stuck.
Old Feb 6, 2007 | 11:12 PM
Default RE: Cooling system
No, change out your t/stat using the factory specific temp t/stat.
If it still happens, you will need to have someone test the temp sensors and see if the coolant sensor if failing which will cause the engine to run way to rich.
My 99 d2 reaches normal operating temp here in Denver on a -0 sort of morning in about 10 minute.
Mike
Old Feb 6, 2007 | 11:38 PM
esaycho's Avatar
It would be better if i chose my words better, it reaches NOT when idling or at low speeds say 25 MPH, but at highway traveling it cools down about halfway inbetween the blue mark and the middle of the guage
Old Feb 7, 2007 | 11:51 AM
Then again I would suggest you have some hook into your system and verify your engine temp trru the OBD2 port. Then you can see what exactly is going on and what to replace to correct the issue. What ever you do, don't try and restrick the air flow thru the radiator, you'll loose and engine one daqy when you least expect it.
Mike
Old Feb 7, 2007 | 12:08 PM
esaycho's Avatar
Ok thanks, I hear about people doing it to diesel's and thought maybe it would work with gas, but then again diesel is a whole different beast
Old Feb 7, 2007 | 12:24 PM
You can do it with a diesel cause the more heat they can have, with in limits, the better they run, which is of course not the same for a gas engine.
Mike
Old Feb 7, 2007 | 02:25 PM
esaycho's Avatar
Yea, I know more about diesels then gas, specifically the 7.3 and 6.0 powerstroke motors, but i'm catching up in knowledge with the rover gas 4.6 v8
muellerny
Feb 28, 2008 08:01 PM
Low Down And Dirty
Dec 25, 2007 05:20 AM
2002FreebieSE
Freelander
Jul 9, 2007 07:31 AM
Darover
Jun 12, 2007 04:18 PM
jkeving
Apr 11, 2007 11:27 PM
