Sponsored by: CARiD
00 Disco with air in cooling system
Old Jan 9, 2008 | 10:32 PM
muellerny's Avatar
Default 00 Disco with air in cooling system
Bought a 2000 Disco from dealer off-lease so I'm 2nd owner. Cared for the car as one should but recently developed a strange sound of coolant flowing through the system. Private mechanic/UK car specialist researched and advised air was getting into cooling systemfrom somewhere.Sounds like a tidal wave in my dashboard! He thinks we're talking about an engine rebuild so I need a 2nd opinion. Since then I burst a hose so stopped driving the car. Only has 96K miles but I don't know what to do with it. Anyone else hear of this problem or got some advice? MM
Old Jan 10, 2008 | 07:59 AM
Default RE: 00 Disco with air in cooling system
You need to have a mechanic do a coolant pressure test, you either have an internal or external coolant leak and this will find it quickly.
In the mean time, you need to bleed the syswtem of air or at least fill the coolant bottle to the very top and check it every morning while the engine is cold.
Old Jan 10, 2008 | 05:15 PM
muellerny's Avatar
Thanks Mike. I did have the coolant pressure tested and the mechanic determined it is an internal leak. He believes the sleeves (?)have given way and air is getting past them. The pressure built up to the point that I burst a hose - hopefully that's all. I'm not sure what to do next b/c it sounds like an expensive fix. Mike M.
Old Jan 10, 2008 | 08:12 PM
How many miles on the engine and has it ever been allowed to get overheated???
Old Jan 10, 2008 | 08:49 PM
muellerny's Avatar
96K. Never overheated to my knowledge although I replaced head gasket last year bc it started to run hot
Old Jan 11, 2008 | 08:54 AM
Hvae you checked to see if you have intermixed fluids/coolant in the oil?? If not go check, if there is no coolant in the oil, chance are you haven't dropped a sleeve, you just have a blown head gasket.
Get back to us.
Old Jan 11, 2008 | 06:04 PM
muellerny's Avatar
Thanks Mike.I'll post again when I get to the car. Had to leave it on Long Island for now (I'm in Jersey). Appreciate the help so far - I'll be back in touch. Mike M
Old Jan 27, 2008 | 07:14 PM
muellerny's Avatar
Hi Mike - I finally got to see my 00 Disco again and confirmed that there is no evidence of coolant mixed with the oil. I did burstthe lowerhose from the radiator to the engine, and coolant was seen leaking from the plastic reservoir (from what looks like a thin pressure release hose). I had the head gasket replaced about a year ago at a cost of $1800 at a private repair shop. Do you think it's a better idea to take it to the dealer for an official diagnosis?
Thanks as always for your help and guidance. Mike M.
Old Jan 27, 2008 | 07:21 PM
I would find a good local shop, the dealer just don't know how to trouble shot problems any more and just like to throw the book at you.
Old Jan 27, 2008 | 07:50 PM
muellerny's Avatar
Any particular type of shop - general repair, engine specialists, cooling system specialists? What are you thoughts on national chains like Pep Boys, Firestone or Lee Myles for this kind of stuff?
