The dark side of K&N
Old May 19, 2006 | 02:29 PM
CronicJoeBlunt's Avatar
Default The dark side of K&N
There is no question that K&N filters are good but be warned there is a dark side, I just ruined my MAF (mass air flow) Senor yesterday because I apparently put too much oil on my filter after I cleaned it, I didn't think I did but then it is really close to the MAF. Fortunately I had a spare one but they are not cheap so hopefully my experience will save someone else from learning it the hard way as I did.
Old May 27, 2006 | 12:46 AM
jgascon37's Avatar
4th Gear
Default RE: The dark side of K&N
thanks for the heads up...
Old May 28, 2006 | 12:43 AM
Bait's Avatar
Perhaps K&N could respond to this thread? MAFS oil contamination from their filters?
Thanks,
Old May 28, 2006 | 01:12 PM
esaycho's Avatar
I hear about this happening all the time. You can't over oil the filter. Really you should just use as little as possible
Old May 28, 2006 | 02:24 PM
I went thru 2 MAF's under warranty on my 99 before I figured it out. I would even go the the extent of soaking up all excess oil on the filter by wrapping them in newspaper for a few hours. The paper really would soak up alot, but not enough.
When you think about it, The volumn of air going thru that filter under full throttle could cause a thin film of oil to build up and trashing the MAF.
Mike
coastie
Nov 19, 2012 08:43 AM
ruffram
Sep 1, 2011 08:15 PM
kenk
May 15, 2011 11:46 AM
Spencerfitch
May 11, 2011 10:27 AM
sloppyjoe
Oct 3, 2010 08:25 PM
