deck installation
Old Dec 29, 2007 | 02:31 PM
dmm698's Avatar
7th Gear
Default deck installation
hey guys just wondering if anybody has installed a 7 inch flip out deck into a p38 on here and could give me an idea on how difficult a task it will be to tackle.
thanks in advance
Old Dec 29, 2007 | 09:55 PM
wease206's Avatar
Default RE: deck installation
all you have to do is remove the window switches then the gear wood grain then the side pandle then the heat-controller after the heat-controller under were is the heat-controller remove the nut to release the deck. Then after that you have to remove all four door pandle and disconnect the amp and run str8 to the woofer use the coler from the stock deck to now what color to cut. If you don't do that then your new deck would not correctly. you also have to disconnect the sub amp too. If you want to keep the wheels controll go to www.pac-audio.com
Old Dec 29, 2007 | 10:30 PM
dmm698's Avatar
7th Gear
hey just wondering which panel you ment by the side panel, and what exactly has to be disconnected in each door panel?
thansk
toad2
Jul 1, 2012 06:56 PM
Kale
Audio/Visual Electronics
Jan 9, 2009 10:46 AM
caspian
Apr 5, 2008 08:45 PM
andrewkim06
Oct 28, 2007 09:45 PM
WGM
Apr 14, 2007 10:32 AM
