eas valve block oring lubricant
Old Mar 22, 2012 | 11:08 AM
bobco's Avatar
Default eas valve block oring lubricant
Hi i have a 2002 4.6 hse range rover i think i might need to relubricate my orings on the eas valve block whats the best lube for the job silicone? thanks for any help.
Old Mar 23, 2012 | 02:28 PM
krazzz's Avatar
I use petroleum jelly on mine. As far as I know that's what most guys use.
Old Mar 23, 2012 | 05:35 PM
threalassmikeg's Avatar
exactly... use vaseline, and get new orings
Old Mar 26, 2012 | 07:05 PM
Mrmerlin's Avatar
a better option for the O rings is to use Dow Corning 111 its a non setting silicone sealant similar to dilectric grease but its not Dielectric grease.
The DC111 will work well on any rubber you have thats drying out or getting hard, it works best when used on initial assembly of O rings.
Works good on the BMW coolant hose O rings as well they wont dry out and leak
DavC
Jun 10, 2020 10:28 AM
bobco
Oct 9, 2010 10:13 PM
nickm347
Feb 16, 2010 01:00 PM
lewis051184
Apr 2, 2009 08:18 PM
raid13
Jan 13, 2008 07:38 PM
