Electrical Gremlin/ ABS Pump 95RRC
Symptoms:
Once my 95 Range Rover County has been driven for awhile and reached operating temp, the ABS pump will kick on and cause the ignition, stereo, lights, to cut out for 1-2 seconds. This usualy happens when I'm pulling up to a stop sign resulting in a near stall of the engine (but it has only stalled twice). Once in awhile, doing normal freeway driving, i'll hear the abs pump will kick on and the stereo will die plus the spedo goes to 0 for a second then back to 65-70mph (this does not happend every time though).
Corrective action:
So far I've replaced the alternator, the battery, and cleaned the 3 ground connections that i could locate under the hood.
-There are no EFI codes displayed
-The battery always has tons of juice (if the car dies it fires right up with no slow cranking)
-The problem seems to be worse when it is hot outside
Thanks in advace for any advice!
Steve
Corrective action:
Steve
Gojobby
04-19-2012 06:44 PM
TenMan1
07-31-2011 10:32 PM
