Electrical Problem! I think...
Old Aug 24, 2008 | 10:33 PM
wizardmagu's Avatar
Default Electrical Problem! I think...
96 RR HS
I have noticed for a while now that my inside message center, interior, and headlights have a slight flicker. They never actually go completely out, but now my HVAC unit screen goes blank and all buttons turn off??? When this occurs the entire heat/air con shuts off (motors and all) and comes back on shortly after. I do notice that my headlights are flickering alot and I don't know how to fix this electrical problem. Another strange thing is that when the key is in the ON position (car not running)ALL the lights work fine, but about 3 sec after turning on the vehiclethe lights flickering begins. Im no mechanic, but I think the problem might be related to something running with the vehicle on???The following are some items that I have done to troubleshoot:
[ul][*]Had bought a replacement HVAC unit and swapped them out and problem still occurred.[*]Began to pull a whole bunch of fuses (1 at a time) and tried starting the vehicle to see if I could crack down on a certain problem... still no change in the flickering lights.[/ul]
More info...
I did havea problem with the vehicle draining a brand new batter within a month, but haven't had any more problems with it... I took the alternator in to get it tested and they said it was good. So I changed the serpentine belt and havent had anything come up.
ANY INFO WOULD GREATLY BE APPRECIATED... WINTER IS COMING AND I NEED THE HEATING SYSTEM TO STAY ON WHEN I DO NEED IT! Taking it to a dealer/mech to find the electrical problem will probably be really EXPENSIVE, so any info would be apprecieated.
Thanks in advance
Old Aug 25, 2008 | 08:14 AM
Rotorhead1959's Avatar
Default RE: Electrical Problem! I think...
Have you tried pulling the relay that controls the heating system? Also, how was your alt. tested? It definitley sounds as if you are getting a heavy draw and an automatic breaker is doing its job by shutting the power off then resetting giving that flickering. I would continue with isolating each relay one at a time. I hate those elect gremlins.
Old Aug 25, 2008 | 10:23 AM
wizardmagu's Avatar
Will try pulling this relay today and let you know. When I had the alternator tested 2 of 3 parts stores had trouble testing the alt because they said they usually hadn't seen that style of alt??? AutoZone checked it said that it was working...it didn't give a ready out... just a GOOD! Like I said in my initial message about the problem only happening when the vehicle is running.
Old Aug 25, 2008 | 07:47 PM
roverguy7's Avatar
it sounds like you need a alt. not that it isnt charging, which is probably what was checked, but the rectifyers inside it, they are what turn the a/c voltage that your alt normally produces into a nice steady flow of d/c that your car can use, they go bad and youre essentially turning the power on and off and reversing it very quickly, itll cause a flicker. its a standard bosch alt so you should be able to find a replacement rectifyer, also called a diode pack
Old Aug 26, 2008 | 06:13 PM
wizardmagu's Avatar
Thanks for the help guys... I will be picking up an alternator this weekend hopefully. Where could I find a good price on an alternator?
I checked my local autozone and they sell their DURALAST Brand alt, but would it be best to go with a BOSCH?? I also found a shop called ALL FOREIGN and they had a Beck Arnely for $200... let me know what guys think about which type of alt to go with.
Old Aug 26, 2008 | 07:10 PM
roverguy7's Avatar
bosch. the electrical systems are touchy to say the least, get what it takes... have you checked on getting just a diode pack? itll be much cheaper
Old Aug 27, 2008 | 07:45 PM
wizardmagu's Avatar
Having some trouble finding the diode packs and I think it would be easier to just replace the alterntor... I found this BOSCH online http://www.car-stuff.com/landroveralternator.htmseems like good deal. What do you think? Or where would you get your parts from? My local autoparts stores dont carry BOSCH. Another question do I need a 100 amp or 120 amp? The website shows 2 for a 96 RR 4.0?
XxRoverAllOverxX
Mar 23, 2012 04:49 AM
lipadj46
Aug 19, 2009 06:11 PM
shadow
May 12, 2007 07:44 AM
indigenous1
Oct 14, 2005 08:30 PM
kfordric
Aug 31, 2005 08:17 AM
