Failed smog
Old Dec 12, 2011 | 12:16 PM
chaz614's Avatar
Question Failed smog
Good Morning Ladies & Gents,
I recently failed a smog test, due to my CO%. The Limit is approx 1.1, I'm at 8.1 I'm basically burning RAW fuel. So I took it to a mechanic and he was baffled as to why there is NO engine light dancing on my dash? Everything is functional on the dash. So now I will need to leave it with him for at least a week to map out the cause. His thought is it could be the injectors or a lot of Carbon build up. If any one has experienced this issue before PLEASE OFFER ME SOME Insight of what may be causing this and worse case scenario of cost. it's a 99 RR 4.0s with 134k.
All the best,
Chaz
Old Dec 12, 2011 | 05:19 PM
When was the last tune up?
Have you ever had your O2's replaced?
Old Dec 12, 2011 | 09:29 PM
jafir's Avatar
Being a 99 RR, is it a Bosch engine or a Gems engine?
GEMS vs BOSCH Engines - Discovery I, Series II, Range Rover 4.0 & 4,6 - Tech Tips at RoverParts.com
Old Dec 13, 2011 | 12:52 AM
psykokid's Avatar
If it were dumping that much fuel it should be throwing a ton of codes. What shop did you take it to? I'm local and there are only a few indy shops in the area that are worth a dam. Did the mechanic hook it up to a scanner? A week to even give you a rough estimate of what is going on is way too long imho.
Old Dec 13, 2011 | 10:12 AM
chaz614's Avatar
I just bought it used about a 2 months ago. "I know, I know no smog cert..." The mechanic did not hook it up to the scanner. I just stopped in and wanted to see if i could get a quote first...due to finaces right now. He is an honest mechanic, but i'm assuming he doesn't have a scanner if it's going to take him a week to figure it out?? The shop only deals with Jags & LR/RR. Thanks for all your inputs
Old Dec 13, 2011 | 10:13 AM
chaz614's Avatar
GEm Engine...
Originally Posted by jafir
Old Dec 13, 2011 | 04:28 PM
jafir's Avatar
Does the engine warm up? Do your cats rattle? I would lean towards O2 sensors or dirty MAF or both. You should be able to see if the injectors are leaking by putting a fuel pressure gauge on it and seeing how long it holds pressure after turning the key off.
yvonne67
Jan 19, 2011 08:47 AM
Carl082974
Aug 16, 2010 11:44 AM
JMON
Jul 30, 2009 09:28 PM
sfxgamer
Aug 17, 2007 09:05 AM
evoasis
Nov 17, 2006 10:31 PM
