Fan problems
RE: Fan problems
I get this same problem once per year on a 96 at almost the same time - in fact a few weeks ago when I went into get one of the relays, the receipt from the one last year was 2 days off of this year. While the relays in mine look good, just one prong on the lower relay, each year "burns" out. I get a replacement from Napa and put it in - notebook goes away, all works. Local shop told me it's a common problem as the AC
runs more during summer and just burns relay up. Don't think this is a "technical" solution, but it's a $24 fix for a annual problem on a car that is
getting limited driving by our teenagers...
RE: Fan problems
Hello my name is Ernie i just buy a 96 Range Rover i havethis problem with my range buy my after like 10 minutes that the A/C is working it wont send the air cold anymore i don't know if is this a relay problem also. and also i will like to ask if you some of you know that is normal that the engine fan is working at all time of it has to turn off and on at setting temperature?
twilightcall
03-04-2018 06:55 PM
rover1978
09-26-2009 09:05 PM
