Fan problems
Old Aug 21, 2008 | 01:18 AM
tayfutbol's Avatar
4wd High
Default Fan problems
Hi I have a 97 rover and the fan has stopped communicating with the brain. The air conditioning and heater are still working great with temp the fan has just stopped pushing air thoughout the car. I took the fan out and tested it, and it still works fine. Any insight?
Old Aug 23, 2008 | 11:35 PM
mlshelton's Avatar
Default RE: Fan problems
Do youhave the notebook error signal in your LCD display?
There's 2 blower relays in the fusebox under the hood - have you checked them?
Old Aug 25, 2008 | 07:19 PM
tayfutbol's Avatar
4wd High
Ya, the notebook is on and I checked the fuses and they were still good.
Old Aug 25, 2008 | 09:47 PM
mlshelton's Avatar
I get this same problem once per year on a 96 at almost the same time - in fact a few weeks ago when I went into get one of the relays, the receipt from the one last year was 2 days off of this year. While the relays in mine look good, just one prong on the lower relay, each year "burns" out. I get a replacement from Napa and put it in - notebook goes away, all works. Local shop told me it's a common problem as the AC
runs more during summer and just burns relay up. Don't think this is a "technical" solution, but it's a $24 fix for a annual problem on a car that is
getting limited driving by our teenagers...
Old Aug 29, 2008 | 03:31 PM
tayfutbol's Avatar
4wd High
Hey thanks for all the help. However I am having trouble testing the relays, how do I test the relays? I switched the fan relays that are in the 6 and 7 spots with other relays that I thought were working. However I am still not getting anything working.
Old Sep 4, 2008 | 02:00 PM
Ernie17's Avatar
Hello my name is Ernie i just buy a 96 Range Rover i havethis problem with my range buy my after like 10 minutes that the A/C is working it wont send the air cold anymore i don't know if is this a relay problem also. and also i will like to ask if you some of you know that is normal that the engine fan is working at all time of it has to turn off and on at setting temperature?
jafir
Feb 10, 2017 11:08 AM
Eak69
Apr 6, 2010 04:50 PM
rover1978
Sep 26, 2009 09:05 PM
jmt
Jan 14, 2008 05:01 PM
