Fuel Pump Failure-Aftermarket options ?
Old Aug 12, 2007 | 01:49 PM
kjj0506's Avatar
Default Fuel Pump Failure-Aftermarket options ?
My pump went bad and after pulling it I noticed that the failure was a short that caused the connection in the tank to melt. It seems to me that and aftermarket pump and fuel pressure regulator would be an improvement in design , less expensive , easier to service and tune if needed.
Has anyone done this on a 90 RRC like mine ? Does anyone know the optimal pressure ?
Any info would be appreciated ....
Old Aug 12, 2007 | 05:17 PM
Default RE: Fuel Pump Failure-Aftermarket options ?
Talk with Auto Zone, I have heard a number of people who have crossed referenced other fuel pumps to fit well with Rovers.
Old Aug 12, 2007 | 07:20 PM
kjj0506's Avatar
Thanks Mike , I am actually looking to get mine out of the tank. I am looking to build roadside servicability into my rig as it will be taken on some very long distance drives. I am trying to get some of the idiosyncratic issues a little more friendly to address repairs on if I have a break down in the desert or whereever. If I get the pump out of the tank and swapped to a more standard style it will be better. I am also trying to increase the fuel pressure slightly as the folks at RPI say it improves the spray pattern on the injectors and gives slightly better performace and economy.
Thanks for the tip though. Much appreciated
Old Aug 12, 2007 | 08:12 PM
The idea is good, I wouldn't try to boost the pressure, the fuel pressure regulator will just restrict it.
Old Aug 12, 2007 | 09:23 PM
kjj0506's Avatar
So do you know the pressure that the factory regulator regulates to and any reason why replacing it with an aftermarket adjustable regulator wouldn't work to increase the pressure even 1-2 lbs?
Old Aug 13, 2007 | 07:23 AM
You might want to talk to someone more experienced with the technical side of injectors. I think I remember heaaring that you really need to stay with in a certain pound pressure or change out the injectors. Let me know what you do and how it works.
Travelor
Sep 24, 2015 06:11 PM
br0keit
Aug 19, 2012 10:58 PM
0304Disco
Jun 15, 2012 02:00 PM
RobertBrowning
Apr 19, 2012 06:04 PM
JumPeR04
Apr 7, 2011 09:52 PM
