Gas
Old May 23, 2008 | 04:29 PM
jjballer1's Avatar
Default Gas
Would it be a smart idea to stop putting premium gas in my 2001 Range Rover? Will it start messing up if I put regular gas in it? Tell me what you think!!
Old May 23, 2008 | 08:32 PM
roverguy7's Avatar
Default RE: Gas
youll have problems. even though its a low compression engine youll get a ping, ignition knock. generally this is caused because the cyl heads run pretty hot due to no egr system and a pretty good fuel managment system. anyway, i dont recomend going below 91
Old May 24, 2008 | 08:01 AM
Default RE: Gas
Just because gas is more expensive, that doesn't mean your Rover will now run on less expensive regular, won't happen.
You will loose at least 2 MPG, some low end power and carbon up your engine causing you Hundreds of $$$$$$$$$$$$$$$$$$$ in repairs.
Do smart things to get the most from your gas, higher tire air pressure, better maintance, some additives once or twice a year, drive slower and shorter trips.
Old May 27, 2008 | 06:26 PM
4.4Range's Avatar
Default RE: Gas
ORIGINAL: jjballer1
I think you should go for it and report back to us in a couple thousand miles...[sm=alcoholic.gif]
Old May 27, 2008 | 06:43 PM
alsuch's Avatar
Default RE: Gas
You could probably save a few bucks by filling up with a half tank of plus (89) and a half tank of super (93) and still be within the 91 octane guideline.
Old May 28, 2008 | 08:54 AM
rodrick smith's Avatar
Default RE: Gas
well mine isn't a 2001 but it is a 1999 and i have always used 89 every blue moon i use 93 but i have been doing this for years and i have no major engine problems, but i am also an idiot when it comes to cars so take it for what it is worth. I fixed my gas problem. i walk 2 block take a bus and then take a metro train to my job. i now only drive when i get home so maybe 3 miles a day :-)
Old May 28, 2008 | 09:06 AM
Default RE: Gas
If you guys can't afford todays gas prices, drive less, stay out of the throttle so much and stay under 65MPH, or do like I do and don't drive it every other day, just don't screw with the gas, 91 plus is the only gas to run.
Old May 28, 2008 | 06:02 PM
72chevy's Avatar
Default RE: Gas
Plus the less you drive your Land Rover, the better chance you will prolong expensive frustrating mechanical problems, but no guaranty.
Old Aug 8, 2009 | 11:08 PM
krazzz's Avatar
I have had two Discos that I always ran regular in. Between the two of them I put on over 80,000k with no engine problems. I did use Lucas fuel treatment every couple weeks and that may have helped keep things clean. I have only put a few thousand miles on my 4.6 HSE but haven't experienced any performance issues running regular.
Old Aug 8, 2009 | 11:43 PM
handsome rob's Avatar
It really does not cost that much more to run the proper gas. I would say on average the premium is about .20 more per gallon than regular. Based on a 20 gal fill up that is only $4, if that is too much money for a week of driving for you then maybe do not go eat at McDonalds one day and you will actually be making money ($6 for a meal).
Mike is right, if the cost bothers you then drive a different car some fo the time, I bet though the pay off fo the cost of that vehicle would equal many years of premium fuel for the Rover.
