getting hot
Old Jun 1, 2009 | 01:40 AM
Mountain_Ox's Avatar
Default getting hot
my 92 rover is getting hot on the freeway. drives fine in town. replaced the thermostat an flushed the cooling system twice. i hava 50/50 mix anti freeze.
could my water pump impeller be bad? has anyone had this problem?
also could plugged up cats also possibly cause it to get hot. the rovers low end is great. but on the top end it seems like its getting held back. also my exaust very smelly. stinks like rotten eggs.
any ideas.
also the head gaskets are good. cooling system pressuer tests fine an so do the cylinders.
Old Jun 1, 2009 | 05:42 AM
wilson96rr's Avatar
I believe the rotton egg smell points to the catalytic converters but I doubt that would cause it to run hot. I also doubt it is the water pump. Before you start replacing things make sure that it is actually running hot. I replaced lots of cooling system parts on mine before I realized my "overheating" problem was actually a bad ground. Check your grounds. Check the connection at the sensor too. If it is really overheating, check to make sure you filled the coolant correctly and have no air pockets. Also check your viscous fan clutch and for debris in the radiator fins. Pays to check the less expensive stuff first. Hope that helps.
Old Jun 1, 2009 | 10:54 AM
i will check the grounds. every thing else is in order. the electric fans click on. an i cycled the cooling system an topped it up. but i know it has been getting rather hot.
dgilson4
Oct 22, 2011 07:04 PM
Disco Ed
Dec 31, 2010 12:10 PM
eddyendo
Jun 1, 2008 04:41 PM
herblatham
May 5, 2008 09:24 PM
aladisco
Jun 20, 2006 11:37 AM
