Glove Box Won't Open
Old Apr 27, 2008 | 11:56 PM
SEMills35's Avatar
3rd Gear
Default Glove Box Won't Open
I have a 2003 Range Rover and my glove box is closed and won't open.
Can anyone help me get this thing open without damaging my dash??
Thx!
Old Apr 28, 2008 | 08:22 PM
roverguy7's Avatar
Default RE: Glove Box Won't Open
its a pain, but can be done. you want to remove the rh side dash closure trim, whats covered by the door when its shut. the almost triangle piece will pop off, gently pry it off(dont pry against the wood, it will break, and its damn expensive) once thats off comes the hard part, you need a long rod with something like a short 90 degree tip on one end, with a light, look into there, at about the halfway point of the glovebox you can see the latch, youll see the cable there too, easy way is to pop the cable back down into the latch, if you can, if not youll have to pull back, towards the front of the car. there is a small piece in the middle of the latch that will slide. good luck.
Old May 4, 2008 | 10:32 PM
Noyanks's Avatar
Wo, Wo, Wo, slow down, first check that the glove box is'nt locked...im just sayin.
Old May 6, 2008 | 10:30 PM
roverguy7's Avatar
yeah, not a bad step one
sleepy740
Jul 9, 2009 01:01 PM
willlane
Mar 3, 2008 07:50 AM
jdelp
Apr 26, 2007 10:21 AM
BuffaloRider
Feb 15, 2007 11:30 PM
spiderfreak80
Mar 16, 2006 03:19 AM
