Is this a good rover?
Old May 31, 2016 | 07:50 PM
Rangerovernoob's Avatar
3rd Gear
Default Is this a good rover?
Hey everyone I am new to the forum but I have loved classic range rovers for a while and have been looking to buy one! There are only 3 for sale locally 2 1994s and 1995 and 2 of them are 10k way over my budget but yesterday a guy posted 1994 Lwb for 1000 dollars! It looks to be in good shape in side and out but there is some rust on the rear hatch( I hear that's common) and also the transfer case doesn't seem to be working? It runs and drives on 2wd. Does this seem like a good deal? I know a lot of it depends on maintenance and if it's been beaten on. How hard is it to replace the transfer case? Is it rebuildable? Thanks!
Old Jun 1, 2016 | 08:24 AM
Jagfixer's Avatar
All Rover parts can be rebuilt and replaceable. Just depends on your expertise and knowledge to do it yourself and save a ton or do you need someone to do it for you, expensive. You will need the Rover Rave Manual and lots of tools.
Old Jun 1, 2016 | 09:59 AM
3rd Gear
Yea I am pretty experienced with repairs. I have done all the repairs on my car for the last 4-5 years including and engine and tranny swap. I have just always heard the rovers are pretty different. I've only owned euro cars so that might help. how hard is it to rebuild the transfer case?
Old Jun 1, 2016 | 12:07 PM
Shiftonthefly1's Avatar
Old Rovers are way easier to work on than most cars. That probably has Borg Warner case in it. You could swap it for the better (insert forum argument here) LT230 case out of any Discovery. Much easier to find. Only needs minimum mods to work.
I don't know where you are but I have a complete BW case in my garage you can have for free. It worked great in the truck I pulled it from.
Old Jun 1, 2016 | 03:11 PM
3rd Gear
I live in mn. So how hard would a swap be for the transfer case? And are the disco one locking?
Old Jun 2, 2016 | 06:11 AM
drowssap's Avatar
Be sure to check it for rust, inside the rear doors and wheel wells where the belts mount are quite common.
Old Jun 2, 2016 | 09:54 AM
Paul Grant's Avatar
Easier if you have a lift, that's for sure. You'll need the transfer case, right frame rail mount, front driveshaft and the linkage in order to get this to work. You'll also need to do a little work to the transmission tunnel. Try to get all the small bits from whomever you buy the case from. Also, you'll need to widen the cutout for the transfer case shift lever as the BW only goes front and back whereas the LT230 pattern is an H.
If you decide to go this route, let me know. I have a number of transfer cases and all the other bits as well.
Old Jun 2, 2016 | 12:25 PM
BritishautoworksSD's Avatar
Look out for ABS problems. Majority of the parts for the ABS system are now out of production. Stuck using used parts if needed.
The transfer case on a 94 rr has a viscous coupling; most likely why it is stuck 2wd.
I agree with changing to a LT230 transfer case for more reliability and better performance, especially on the dirt.
This some pretty advanced work and would recommend this to someone is a season mechanic.
Philhowe
Feb 24, 2008 08:12 PM
grrRover
Dec 4, 2007 05:19 PM
mc_eyes
Nov 8, 2007 10:48 PM
Slipknotkid09
Feb 3, 2007 09:57 AM
sopjih
Sep 9, 2006 02:38 PM
