heater probs!!!
RE: heater probs!!!
You won't get actual codes with this, it can still give you a diagnosis
http://www.rangie.com/articles_model...d=72&modelId=2
on
RE: heater probs!!!
ORIGINAL: slackwaresupport
is there anyway to diag. the ! without taking to dealer??
ie.. autozone or somewhere
Mike
RE: heater probs!!!
Are you talking about a Discovery or a Range Rover? (2000 HSE is what you mentioned) If a RR, then a common part failure that shows the symptoms you describe is the Blend Door actuators, and in some cases it can also be a failure of the main heater control panel which has to be replaced as a complete unit.
Regards,
Geoman
www.eurotekapg.com
Regards,
Geoman
www.eurotekapg.com
