heater probs!!!
You won't get actual codes with this, it can still give you a diagnosis
http://www.rangie.com/articles_model...d=72&modelId=2
ORIGINAL: slackwaresupport
is there anyway to diag. the ! without taking to dealer??
ie.. autozone or somewhere
Mike
Go to the dealer, cause bottom line even if you evidentily find out what is wrong with it, the dealer will need to be the one to make the repair and reset the system.
Mike
Mike
Are you talking about a Discovery or a Range Rover? (2000 HSE is what you mentioned) If a RR, then a common part failure that shows the symptoms you describe is the Blend Door actuators, and in some cases it can also be a failure of the main heater control panel which has to be replaced as a complete unit.
Regards,
Geoman
www.eurotekapg.com
Regards,
Geoman
www.eurotekapg.com
