HELP
Old Nov 25, 2007 | 01:15 AM
bobbydave's Avatar
Default HELP
my ABS, Traction control and brake are all lit up on my dashboard. I've noticed that when i'm going above 50mph and hit a bump my front tires shake bad. i have to brake and slow down to stop it. I'm guessing that shaking is due to the spring convertion i had done i also had the truck raised 2 inches when i did the convertion. the truck also pulls either right or left depending on the road at times i feel like i'm going to loose control.
Old Nov 25, 2007 | 02:10 AM
llesra's Avatar
Default RE: HELP
what year is the truck? when is the last time the pads/rotors were changed out? for the shaking, check the panhard rod bushings. they are probably worn out.
Old Nov 26, 2007 | 03:02 PM
bobbydave's Avatar
Default RE: HELP
its a 1999 hse
Old Nov 26, 2007 | 03:22 PM
Default RE: HELP
Start with a new steering stabilizer, Old Man Emu, then look at your tires and or alignment to correct the wheel shake.
When that is all taken care of then you can tackle the ABS issue.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
