Help RR 98SE
Old Dec 31, 2006 | 09:14 PM
RCHILDRESS's Avatar
7th Gear
Default Help RR 98SE
I am a new P38 owner (at least its new to me), the previous owner gave me 2 keys/remotes 1 recently just stopped working I change the batery's but the ligh wont come on when depressed and the other isnt programmed to the vehicle. Does anyone know how to program a remote?
Also the check engine light is on I have had the codes read and did some research on them they are
[align=center]
P0116
Engine Coolant Temperature Sensor Falling Temp Fault [/align][align=center]
P0125
Engine Coolant Temp Sensor Warm Up Fault [/align]
and
[align=center]
P0118
Engine Coolant Temperature Sensor High Out of Range Fault [/align]assumably there is an engine coolant issue, I dont know how to reset the light on this vehicle to confirm that there is an issue can I get a little direction from you fine people?!?!?
Thanks....
rqchildress@bellsouth.net
Old Jan 1, 2007 | 11:15 AM
Default RE: Help RR 98SE
My first guess for the year would be that all 3 codes are caused by the 116 code and I would believe that replacing the sensor should allow the other two codes to be cleared.
Let me know what happens,
Mike
Old Jan 1, 2007 | 04:27 PM
esaycho's Avatar
To program the remote, make sure the alarm is not set, and the doors are unlocked, press the lock button on the remote, and then quickly insert the key into the door lock on the drivers door and turn it to the lock position. It should work, that's exactly what I did for my remote
Old Jan 1, 2007 | 07:23 PM
RCHILDRESS's Avatar
7th Gear
Thanks Disco Mike for the help but I am awaiting a repair manual to be mailed to me, where would I find the sensor and exactly what is it called, also when it is replaced will the check engine light go out on its on?
Also big thanks for a response from esaycho..
I tried programming it but it didnt work. is there another way to try?
Thanks gents, If I could get this done the wife will be really happy!!!
Old Jan 1, 2007 | 08:49 PM
FordCrusherGT's Avatar
I just disconnected my battery while working on my laundry list of issues, and upon reconnecting I hit the buttons on the remote (both of them, one at a time), and then manually locked and unlocked the door and it worked. If that doesn't do it, just keep on playing. On both my Range Rover and my Jaguar I have had to deal with this, and I always end up playing with the remotes and keys and such until it works, and eventually I stumble upon the correct solution.
Best of luck, and I would agree you probably want to replace your coolant temp sensor.
Old Jan 1, 2007 | 09:19 PM
RCHILDRESS's Avatar
7th Gear
I will try the battery trick when the wife gets back from shopping!!! Do you know where I can find the coolant temp sensor? I've got no idea of where the thing sits??
Old Jan 2, 2007 | 02:35 PM
geoman's Avatar
The coolant temp sensor is on the intake manifold-- front--
There are two sensors, one for the temp gage, and the second for the computer. The one you need to replace has a "bullet" type connector (as opposed to the other with a conventional spade connector).
regards,
Geoman
www.eurotekapg.com
Old Feb 26, 2007 | 10:32 PM
RCHILDRESS's Avatar
7th Gear
Default RE: Help RR 98SE/Check engine light still on
Thanks for your help gang!!!. I finally got the sensor in changed itand it runs better and it even starts up better when its warm but the check engine light is still on... Is there a way for me to deactivate it on my own?? I tried removing the battery cables all that did was give me the opportunity to drive for a few weeks without my radio until I called the dealer and they gave me the code. Also I have tried almost every trick in the book to get my remote programmed to the truck.. Any help.... Thanks
rc
Old Feb 27, 2007 | 07:36 PM
geoman's Avatar
The on-board computer stores fault codes, and depending on which combination of codes resulted from sensors having a "out of range" condition --- the CEL will continue to stay on until the vehicle is connected to a Autologic,RovaComm, or TestBook scanner. Only the Dealers and well equipped independent Land Rover repair shops have this scanner. A OBDII scanner --ascommonly found -- only reads and clears basic fault codes.
regards,
Geoman
www.eurotekapg.com
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
