high idle on p38 (pls help)
Old Sep 11, 2015 | 09:10 AM
TOM R's Avatar
Oblonging the holes and turning the sensor is so it gives a lower value to the ecu, it is masking the problem, but will lower your idle, forgot to mention check the cables
Old Dec 4, 2015 | 11:44 AM
newworld's Avatar
1995 rrc.
the poster who suggested tps is correct. unfortunately something came out of whack between ecu and sensor at some point....it needs to be (1) reset with software to get idle setting etc or (2) you can take the tps out and make a sliding/turning where screws are. then adjust when engine is hot and running.
i have the same problem with mine and i dont think i totally fixed it. but i do know you want to adjust when engine is hot and not when start up cold since cold temp sensor loop will run and give you an inacurrate setting point.
if there is a shop that has the landy software they can reset idle base setting for you as well....and they will adjust through ecu software not gerryrigging the tps.
wick_60010
Nov 22, 2017 04:25 AM
provocateur
May 30, 2008 07:17 PM
xstreetz
Sep 16, 2007 06:22 PM
argoman
Defender
Apr 28, 2007 12:32 PM
Disco Kiwi
Jan 31, 2006 07:13 PM
