How to connect ipod to 03 rr
Old Dec 2, 2009 | 07:14 PM
Aj6543's Avatar
Default How to connect ipod to 03 rr
How does one connect a ipod to the rovers stereo?
Old Dec 3, 2009 | 06:28 AM
Bemble's Avatar
3rd Gear
I use an Intravee which allows you to change tracks etc. using the steering wheel buttons and also the tracks are displayed on the nav. screen. It's pretty good, but quite expensive and not particularly slick. You also lose the CD changer, as it taps into the BMW iBus system using the CD changer connectors.
Old Dec 7, 2009 | 02:14 PM
Aj6543's Avatar
Bremble- Where can I get this intravee set up? Any other recommendations ?
Old Dec 9, 2009 | 04:15 AM
Bemble's Avatar
3rd Gear
This is where I got mine :
http://www.toysinyourcar.com/cgi-bin...html%23a62#a62
These guys used to be the only UK supplier (but I don’t know if they still are).
The Intravee basically allows the connection of Alpine’s AiNET equipment onto the BMW iBus used in ‘02-‘04 Range Rovers (Note – this changed for 2005MY), so you will also need the Alpine iPod interface.
There’s an Intravee forum here if you want to do some more research :
http://www.intravention.co.uk/forum/index.php
Regarding alternatives, it might be worth searching on the RangeRovers.net forum
Old Dec 9, 2009 | 07:56 PM
allensp38's Avatar
3rd Gear
Look for a 12 volt modulator. Crutchfield sell a unit for around $50 that plugs directly into the antenna wire between the stereo head and the antenna. It has an input for the Ipod. I haven't actually tried one but I'm looking for a better solution than the 12 volt FM modulator I currently use which is susceptible to FM interference.
robson
Dec 28, 2010 08:25 AM
pvenuti
Apr 17, 2010 05:20 PM
rich
Mar 7, 2010 02:52 PM
johnnyz
Off Topic
Sep 27, 2007 09:02 AM
daisybcb
Off Topic
Aug 4, 2007 08:46 AM
