I am lost, 01 Cruise
I got the books and all but this Cruise Control has got me scratching my head.
I replaced the bad vac hose that attaches to the back of the actuator but not work.
Get the electrical light on the dash at the switch but NO indicator on the dash.
Any idea where to look next or is this a dealer fix?
Thank you
Thank you
I have been through the troubleshooting guide in the Rave manual with mine. I also get the light on the button, but that is it. Did you go through the troubleshooting in the manual? It is step by step and easy to follow. Only problem that I had was after completing it, I still can't get the cruise to work. According to the troubleshooting guide, there is something wrong with my BECM, so, I just gave up. Hope you have better luck.
There is a control module and power inverter under the dash. If it doesn't make the click it is probably one of those two. I had the same problem. I was able to get both of them on ebay for pretty cheap so I just replaced both. I do have occasional problems with it kicking off but it doesn't happen very often and it works again if I turn it off and on again so I don't worry about it.
Well so far NO GOOD, tested, prodded, smacked it a couple of times and nothing.
Local shop says to look at the stop light switch which controls the cruise and is an NO switch that fails in the NO position, makes sense. Thta is my next crawl around to look at.
Back working on my Porsche to get the A/C and Stereo working, electrical gremlin.
