I was Wondering wht is the best year of the Range Rover to go 4-whelling??
Old Aug 9, 2009 | 03:50 PM
LRDalltheway77's Avatar
Default I was Wondering wht is the best year of the Range Rover to go 4-whelling??
I was just wondering what the best year of the range rover is to go 4-whelling?? is the 98 and 97 good??
Old Aug 9, 2009 | 05:41 PM
LRScott's Avatar
They are all good off roaders. It is hard to say what years would do better and I think they would be equally matched if pitted against each other. One with air springs might be better because it will lift itself a bit higher than if it had coils. A range rover classic 1987 to 1995 has the shortest wheel base which, will keep you from grounding out as much. The p38 1995 to 2002 has the air springs to compensate for the longer wheel base. Most have had their air springs removed because they can be expensive to maintain. In either case, all range rovers are good at off roading and I don't think it will matter which one you choose.
78KITCAR
Oct 12, 2012 07:42 AM
jigray3
Nov 13, 2007 04:27 PM
huckleberry
Dec 3, 2006 02:12 PM
abethlen
Jan 9, 2006 09:12 PM
