Instrument cluster zapped
Old Apr 16, 2008 | 06:21 PM
riko suave's Avatar
Default Instrument cluster zapped
Installing a new radio and I accidently hit the hot lead and the instrument cluster that contols the speedo, fuel gauge, oil temp etc and info screen went out.
Checked fuse #8 which is tied to the instrument cluster and the 30 amp fuse is fine.
Is there another fuse that is behind the dash I need to check?
Obviously, with the speedo not working my truck won't be able to get into OD.
Any help would be appreciated.
Thanks[/align]
Old Apr 16, 2008 | 11:17 PM
roverguy7's Avatar
Default RE: Instrument cluster zapped
check fuse 1 in your BeCM. under the pass seat.
[/align]
Old Apr 17, 2008 | 10:09 AM
riko suave's Avatar
My bad Rover, I said fuse #8 above but it was actually fuse #1 that I checked and is fine. Fuse #8 (climate control, cigarette lighter, etc) did blow and Iput in a new one.
Not sure why fuse #1 is fine but the instrument cluster still won't work.
Old Mar 18, 2009 | 04:34 PM
johnboyairey's Avatar
4wd High
Default fuse 1 on p38 blew, cluster inop after change.
i have done exactly as you, and have same symptom. i blew fuse 1, changing my radio, wire fell down and earthed etc. lost cluster gauges, replaced fuse 1 10 amp. and now just a pulsing flicker of life every two seconds, and nothing. car drives without gauges. but problem with lpg backfiring now. how did you clear yours please. 1997 p38 4.0 p.s.
vbkre15
Mar 19, 2010 06:44 PM
Panic
Feb 23, 2009 01:41 PM
CandiMan
Oct 30, 2008 01:39 AM
coldfrez
Oct 1, 2007 09:49 AM
Greg
Aug 8, 2007 04:47 AM
