Keyless Entry
Old Nov 7, 2007 | 09:43 AM
vjm530's Avatar
Default Keyless Entry
On both sets of keys that I have for my '97 Rover 4.0 SE the 2 buttons for the 'lock' and 'unlock' are gone so I have to lock manually which isn't a problem. My question is if I go to the dealer do I have to buy all new keys or can the 'casing' be replaced and about how much $$$? Or is there an alternative? Thanks
Old Nov 7, 2007 | 02:03 PM
bavarian_range89's Avatar
Default RE: Keyless Entry
Good news! The buttons on the p38 keyfob are replaceable. You can order the part online at roverparts.com or you can get it from the dealer. I had to do this about a month ago, I replaced the battery and the buttons on my keyfob for about $10 after tax. I think the buttons are about $3 or $4 dollars. Sorry, not sure of the part number, but the dealer should know exactly what you are talking about.
Old Nov 7, 2007 | 02:40 PM
vjm530's Avatar
Excellent. Thanks soooooo much. How did you seperate the 2 halves of the fob and did you have any problems you can warn me about before I open it?
Old Nov 7, 2007 | 03:07 PM
DO NOT OPEN THE KEY. You simply use a penny or small coin on the back in that slit to open the back if you are replacing the battery, and if you are just replacing the buttons then you just slide the new one into the precut slot. If any of the worn buttons are left on the key you'll need to remove that first, but the new one is an easy insert. You should have no reason to have to actually open the keyfob, and if you do I have no experience with opening it so I have no help for you, hope that helps!
Old Nov 7, 2007 | 05:21 PM
vjm530's Avatar
I see what you mean. I've ordered the part (2). I understand the picture better now. I just bought the car and both sets have the same problem from excess wear I guess. Thanks again.
93Miata
Feb 12, 2018 03:23 PM
Frank4
Mar 21, 2014 05:21 AM
faith2
Sep 14, 2005 03:04 PM
FORDSTANGER
Aug 9, 2005 01:00 PM
pvalianatos
Mar 12, 2005 05:20 PM
