l322 power seats?
Old Sep 16, 2008 | 11:57 PM
Brad S1's Avatar
Default l322 power seats?
I've mentioned this in another thread... My drivers seat and steering column blow fuse 20... I replace it, it works for maybe 2 min, then blows the fuse... Most times when I put a new fuse in, it blows right away. Sometimes the passenger seat also fails, but doens't usually blow the fuse... Are there related fuses I should check? Perhaps an earth point fouled?
Old Sep 18, 2008 | 09:09 PM
roverguy7's Avatar
Default RE: l322 power seats?
are they the contour seats? upper half of the seat tilts also... if so, they had a big problem with the relay inside that motor causing the fuse to blow
Old Sep 19, 2008 | 12:32 AM
Brad S1's Avatar
I do have those type of seats... So what do I do about this? Is the relay a part I can access and replace?
Old Oct 7, 2008 | 05:00 PM
roverguy7's Avatar
no, the relay is intragal to the motor, you need a new 'comfort' motor
Old Oct 8, 2008 | 05:59 PM
Brad S1's Avatar
I did a search, but what is a, "comfort," motor?
TAI
goatman
Jan 12, 2013 10:08 AM
booper169
Nov 9, 2010 09:10 AM
heinzeman
Oct 7, 2010 04:57 AM
gsxrgessler
Jan 26, 2008 08:34 PM
