Lack of Fuel Pressure?
Old Apr 17, 2009 | 01:48 PM
NhudeST's Avatar
Exclamation Lack of Fuel Pressure?
Just found out my RR-HSE is lacking fuel pressure and its not allowing my vehicle to get started. Just added a new Fuel Pump, Fuel Filter, and checked all FP fuses and relay. Does anyone know what it could be? I would really appreciate it.
Thanks a lot.
Old Apr 17, 2009 | 02:30 PM
Probably didn't need all that stuff.
What year is it?
Chance are you may have had a crank sensor fial which will not allow the pump to fire up.
Any Codes?
Old Apr 17, 2009 | 06:53 PM
NhudeST's Avatar
Its a 2004 RR-HSE.
Old Apr 17, 2009 | 09:51 PM
roverguy7's Avatar
sounds like fuel pump. if everything checks out. not terribly uncommon
Old Apr 17, 2009 | 10:51 PM
NhudeST's Avatar
Well, its not the pump, because it just recently got replaced this week, including the fuel filter. I managed to check all the fuses plus found the actual fuel pump relay, and still not working. Vehicle cranks up as though it wants to start, but after about 10-15secs, nothing happens. All its doing its draining out the battery, even though I recently had it checked at AAMCO and they said it still had about 2-2 1/2 years of life. From what the LR Dealer mentioned to me this afternoon is that there was little or no fuel pressure going through, but the FP is working. Other than that, if anyone has experienced the same problem my vehicle just went through, let me know and help a brother out.
Lastly, I did managed to use a OBD-II and only one code came up, P0463 "Fuel Level Sensor A Circuit High Input". Vehicle has over half of tank of gasoline in it. Other than that, no other codes came up.
Old Apr 18, 2009 | 08:41 AM
roverguy7's Avatar
put 5 gallons in the tank. see what happens
Old Apr 18, 2009 | 02:05 PM
NhudeST's Avatar
Exclamation
I've added about 7 or 8 gallons already. Last time I checked it, it read at about a little bit less than 1/4 tank, but ever since I added the extra few gallons, its in between 1/2 & 3/4 of a tank.
Im just going to wait till Monday to see what the LR Dealership found on it, last thing I want to hear from them is that they also dont know what it is..
Old Apr 18, 2009 | 03:29 PM
roverguy7's Avatar
have you checked the fuses under the hood yet?
Old Apr 18, 2009 | 06:47 PM
lrobin3w's Avatar
Where did you have the fuel pump and filter serviced? If the fuel filter lines are not hooked up correctly, the car wont start. fuel will just be returned to the tank.
Old Apr 19, 2009 | 12:16 PM
NhudeST's Avatar
Ive checked all the fuses, including the ones under the hood area, located inside the black box, the ones inside the glove compartment, plus the ones at the end of the vehicle on the right hand side by the rear latch door.
As for the FP and F-filert, I bought both of them from the actual LR Dealership and did the service myself. The vehicle actually stopped working and its was not till afterwords that I purchased the parts after having taking it to a local Foreign Auto Repair shop in Arizona, due to the vehicle breaking down on me over there.
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
Ali
Jul 4, 2007 05:03 PM
skrams
Feb 16, 2007 03:25 PM
RoverLife
Feb 1, 2007 11:16 AM
