Lazy seatbelts
Old Jan 21, 2010 | 07:15 PM
wilson96rr's Avatar
Default Lazy seatbelts
I'm not sure if this is a common issue, but the seatbelts in my Range Rover don't retract very well leading to people closing them in the door. Is there a simple fix for this or do I just need to buy new seatbelts?
Thanks,
Wilson
Old Jan 22, 2010 | 12:10 AM
LRScott's Avatar
Mine do the same thing... Unfortunatley it says in the service manual that they are "oiled" for life so there is not much we can do about it. If you want, you can try greasing it up a bit and see if that helps, but be wary. Its safety you are dealing with.
Old Jan 22, 2010 | 05:13 AM
wilson96rr's Avatar
Ok, thanks. I will pull one out and see if I can fix it. I'll post the results.
Old Jan 24, 2010 | 09:30 AM
Rovin4life's Avatar
spray silicone works best.
Old Jan 24, 2010 | 01:31 PM
wilson96rr's Avatar
Interesting. I'll give it a try. I have noticed that the driver's side works great even though it gets the most use, leading me to believe that the others are not worn out.
Old Feb 7, 2010 | 08:25 AM
wilson96rr's Avatar
Just an update...I used spray silicone on the belts and the surfaces that they slide on and problem solved. Easiest thing I ever fixed on the RR.
Old Feb 7, 2010 | 01:01 PM
LRScott's Avatar
Hmm, I'll have to try it out, thanks for sharing.
DER
Jul 2, 2008 12:01 PM
EL GALLO
May 24, 2008 07:05 AM
jglaza904
LR2
Jan 17, 2008 06:34 PM
trinidev
Mar 19, 2006 11:56 AM
auburndmbfan
Aug 5, 2005 11:39 AM
