a little help with a 1997 LR
I am interested in buying a Land Rover which needs some work. The guy trying to sell the vehicle said there is a ticking noise coming from the engine. I have posted the craigs list ad so you all can see it. I just want to know if this is something I should get into? Questions I need to ask? and things I should look for when checking out this vehicle? Or does anyone have an inkling of what this could be?
Thank you so much
http://portland.craigslist.org/clk/cto/1426442234.html
Thank you so much
The tick is usually a lifter, but not always. Sometimes it is the camshaft being worn down. When and if you go look at it, tell us where the noise is coming from. Lower engine noise is most likely a camshaft, whereas upper engine noise is usually the lifter. A ticking noise can also be a leak in the exhaust manifold. If you want to know exactly what it is and how expensive/hard it is to repair, we are going to need a bit more info.
thank you to everyone that has helped in this.
What would be fair to offer? He said it could be one of three things...sticky valve, bad rod, or a loose pistin. He emailed me back and said he did a bit of research. Does anyone know how much it would be to fix these problems, and is this worth the time and energy?
Thanks again!
Thanks again!
I doubt its a loose piston. These engines are pretty solid, but have head gasket issues and suffer from warped blocks if not taken care of properly. For the sake of doing business, offer him 1k for it and see if you can get it for a steal. Right now its probably worth $2200 or so... Before anything, I would have it inspected by a good mechanic.
LPs HSE
06-19-2007 09:12 PM
