Location of Cruise Control ECU
Old Mar 27, 2010 | 01:35 PM
Weskechi's Avatar
5th Gear
Default Location of Cruise Control ECU
Need to know where the Cruise Control ECU is located in a 2000 RR 4.6 L Vitesse. I suspect it is under or behind the glove compartment. Please advise. If possible, need advise on how to remove and replace it. Thanks.
Old Mar 27, 2010 | 10:13 PM
krazzz's Avatar
Actually it is just above your left knee while you are seated in the drivers seat. Pull off the lower panel you almost have to lay on your back to see it. It has an aluminum housing and is slightly larger than a deck of cards.
Old Mar 29, 2010 | 02:34 PM
Weskechi's Avatar
5th Gear
Smile Location of Cruise Control ECU
Thanks abunch for the info. I have already installed the Cruise control ECU (Used one); however, the cruise control still does not work. Land Rover dealership did the diagnosis and advised that another ECU is needed. Hence, I decided to get a used one. However this used one does not work. I thank you very much for the info.
Old Mar 29, 2010 | 07:16 PM
krazzz's Avatar
Don't forget to check the power inverter and the switch.
EricTyrrell
Feb 18, 2013 11:30 AM
AuZZZie
May 21, 2012 12:01 PM
MrMayorDA
Feb 14, 2012 09:39 AM
Camdisco24
Aug 11, 2009 06:03 PM
BYURover
Jul 18, 2007 09:00 AM
