Losing coolant
Old Feb 1, 2011 | 12:31 AM
LRScott's Avatar
Mine chews through some coolant here and there. The spark plugs show no sign of coolant and neither does the oil. Engine temps are fine, and I notice a leak coming from mine every spring... still don't know where it comes from, but I'd imagine it is the culprit. A compression test can tell you a lot. If your head gaskets haven't been replaced, it might be wise to do so. Pay close attention to details and you will find the cause eventually.
Old Feb 1, 2011 | 07:10 AM
Chris X's Avatar
Its helpful to take a Sharpie or similar ink marker and start marking the coolant levels. Start now and continue to check the level every few days, and re-mark. Then you can really figure out how much you are losing.
Usually if it is near the throttle body you might have a little bit of residue on the valve cover.
Likely head gasket, but may as well check everything else first.
tgwaldop
Nov 20, 2010 02:41 PM
Disco2Fever
Nov 20, 2009 08:19 PM
alpineclimber
May 27, 2009 07:42 PM
kraelo
Apr 7, 2008 11:38 AM
jerome
May 21, 2007 04:26 PM
