lug caps
Make sure you have a 1 1/16" Socket. I personally think these lugnuts have the worst design imaginable. I have yet to find one that I couldn't get off but they sometimes take a bit of work. Get a good dead blow hammer and beat that socket on. Then add a good breaker bar and you should be all set. You may have to jump on it a bit but it will come off.
Mike, I agree with you. If you can avoid taking off the cap then do it. If your lugs are so messed up because a tire shop used a 1 1/8 12 point on it then you may just be out of luck. If you do need new ones because yours are messed up go look at your local wrecking yard. I buy mine there for $1 each. I take out my 1 1/16 impact socket and of it does not slide on easily then I do not buy it and find some better condition ones. With the cash for clunkers deal there were a lot of good lug nuts sitting around and not being used.
nick731
11-29-2010 06:14 PM
