Sponsored by: CARiD
lug caps brakes&rotors
Old Jan 16, 2010 | 12:35 PM
94rover's Avatar
7th Gear
Default lug caps brakes&rotors
is there a way to de-cap lugs? my factory lug wrench wont fit capped lugs? are there any special tools needed to change brakes and rotors?
Old Jan 16, 2010 | 01:01 PM
antichrist's Avatar
Yeah, you can just pry them off, might need a chisel.
No special tools, though a hub bearing nut tool is strongly suggested. Saves you having to use a chisel or big arc joint pliers to remove and install the nut.
You'll need 12pt sockets for the caliper bolts and rotor bolts.
The drive member bolts you can remove with 6 or 12pt.
Loctite 270 for the rotor bolts and drive member bolts.
Old Jan 27, 2010 | 07:49 PM
klackson72's Avatar
4th Gear
quick hint on the lug caps. I was able with some force and a pair of vice grips clamp the caps back down onto the lugnuts and not have to remove them.
Old Jan 28, 2010 | 04:16 PM
94rover's Avatar
7th Gear
Default cut'em off
i was successful in removing caps. i found a shop that used a hand grinder to remove the tops then make a slit into the cap being careful not to make one into the lug itself. then using a small sledge hammer and a heavy duty flat head scredriver chieseled the caps off. it took alittle work but it worked to reveal a 26mm lug. breaks done. didnt need back rotor. front was a different story! THANKS FOR THE SUGGESTIONS. I STRONGLY SUGGEST TO OTHERS REMOVE/REPLACE CAPS.
wolfgang528
Defender
Dec 28, 2010 04:25 PM
nick731
Nov 29, 2010 06:14 PM
LL2Juan
Mar 14, 2010 02:45 PM
94rover
Jan 18, 2010 04:32 PM
farley5150
Feb 20, 2005 11:17 PM
