Making New 2008 Range Rover from Your Old One
Old Aug 4, 2007 | 12:07 PM
smotri's Avatar
Default Making New 2008 Range Rover from Your Old One
Hi Happy Land Rover Owners!
Has anyone wondered about making a new Range Rover 2008, from 2005 model (Exterior Only)?
I mean, what if just change all exterior parts to a new one's (head and tail lights, front and side intake grills, bumpers)?
Will it all fit?
Please Answer Me!
Many Thanks!
Old Aug 4, 2007 | 10:44 PM
wp's Avatar
wp
Default RE: Making New 2008 Range Rover from Your Old One
Hi there,
Changing the headlights would be expensive. They run around $900 each. The front grill cannot be updated unless you update the headlights because they curve into the grill. The grill can be changed to the supercharged grill but not the 2007 HSE grill. What you can do to change the look of your 2005 to 2007 same as 2008 is change the rear tailights (plug and play), change the side markers from orange to white and then change the side vents from two vents to the three vents (just held by screws). You can change the look to an HSE or Supercharged. Hope this helps.
Old Aug 20, 2007 | 10:49 AM
benpatton's Avatar
3rd Gear
Where can you purchase the rear tailights? Thanks. Also, there is a way to get the SC grill without changing the front headlights. You have to buy a pre-modified SC grille. www.simmonites.com has them.
Old Aug 21, 2007 | 11:50 AM
VermontRoverGal's Avatar
Don't want to sound like a "downer" here, but what's the point? You might be able to somewhat change the exterior look of your 2005, but it won't be the Supercharged, and it won't be complete. Or am I missing something?
Old Aug 22, 2007 | 06:54 PM
wp's Avatar
wp
you can look around on ebay or at your dealership for the rear tail lamps they run around $260 at the dealership
Old Aug 22, 2007 | 06:56 PM
wp's Avatar
wp
ORIGINAL: VermontRoverGal
You're right, you won't make your car go faster...but it will update the look of your car to a newer model...some people just like the look of the supercharged grill
Old Mar 1, 2008 | 09:24 AM
4.4Range's Avatar
Does anyone know how to take out the side vents from an '04 Range Rover HSE? I can get the topscrew out, but how in the world can I get to the bottom screw out (if there are any??)?
Old Mar 3, 2008 | 10:40 AM
2cv's Avatar
2cv
You have to take that little panel off right below the vents...looks sketchy, but ur screws are hiding in their....
Old Mar 6, 2008 | 06:32 PM
2cv's Avatar
2cv
100% possible!!!!!!!!!!1
no joke, i considered it and the reason was for looks not performance...!
#1The lights can be switched to an 06' simply by fusing the proper wires together. You will need thelight connector from an 06'+, or just take it to an electrictian..."if he's half smart, he'll see the solution"
#2 Purchase a stock 06' bumper or aftermarket or ask overfinch if they have any left over from previous projects. Including brackets N' wat not...
#3 The dealer will tell you that since the 03-05" has a BMWengine, the frame & brackets &B.S. will not fit the 06' bumper! NOT TRUE! "haters"
#4 Or you can keep your old bumper, go to a 06'+ and apply a clay template with some measurements & cut that groove the 06+' has. Or just pay a bodyshop to do it for you...
#5 Purchase your front grill & side vents. Walahhhhh... You have your self an 06+ Rova!
ellebarto
Sights N Sounds
Mar 13, 2013 11:52 AM
AFAv8r
Nov 18, 2010 10:37 PM
MagnaflowRep
Headers, Intake, & Exhaust
Sep 2, 2009 12:26 PM
Mee
Aug 11, 2005 12:43 PM
