My brakes sound like a machine gun!!!
Old Sep 25, 2007 | 11:36 AM
kjj0506's Avatar
Default My brakes sound like a machine gun!!!
There is suddenly an intermittent rapid fire tick coming from under my dash near the pedal and when this happens the braking goes whacky and I can't stop. The pedal is kicking back when the this occurs as well. It seems as though its trying to go into antilock mode but I am at parking lot speed and in no threat of skid... It has a new Accumulator , new stainless lines , and new fluid as well .
I would love to disarm the ABS if possible and have seen info in places about disconnecting the sensors. Would my symptoms be cured by this ? Does some one have detailed ( read: chimp-proof ) instructions on how to rid my ABS woes ?
Old Sep 26, 2007 | 05:46 AM
dirtyduk's Avatar
Default RE: My brakes sound like a machine gun!!!
Check your front sensors ,push them down all the way, codes need to be checked , to find out which sensor is corrupt, you could have swivel hub problems.
Old Sep 26, 2007 | 11:02 AM
kjj0506's Avatar
I presume this 'sensor' would be the wired item that protrudes down vertically into the top of the top swivel ball pivot ( in the front - the rear ? ) ? I just re-sealed my entire swivel ball and the ABS symptom didn't change ( was there before and after - the swivel ball re-seal was not due to this symptom but was a scheduled repair independent of the ABS issue ) . Any detailed instructions on how to clean , adjust , check , or otherwise take a look at the ABS wheel speed sensors would be fantastic ( my limited manual doesn't show anything helpful ) .
Thanks so much for any input !!
Old Sep 26, 2007 | 06:41 PM
dirtyduk's Avatar
You really need to have the codes checked , if the sensors are installed properly and it continually activates it isint safe to drive.
I dont recomend it but you can try unplugging the ABS ecu or the plug on the brake booster to stop the madness.
rover11
May 26, 2011 11:21 AM
FightOnUSC79
Nov 26, 2010 09:43 AM
imarockstar
Feb 22, 2010 12:19 PM
Chrisinhouston
Jun 28, 2008 10:46 AM
DG
Jun 7, 2007 05:49 PM
