My Rover will not Idle
Old Jul 25, 2011 | 10:52 AM
Jason428sc's Avatar
Default My Rover will not Idle
Hi guys,
I've got a 1998 Range Rover SE 4.0 with 103k miles that I bought with a blown head gasket. I have just finished replacing the head gaskets and it will not idle. I don't know if it had this problem before because it would not start when I bought it. It will crank and run smooth as long as I have my foot on the gas pedal. I have checked for vacuum leaks and cleaned the IACV and the mass air meter with no luck. Is there anything else I should try before buying a new ICV?
Thanks, Jason
Old Jul 25, 2011 | 04:47 PM
Jason428sc's Avatar
Hi guys,
I have an update on the idle problem. I read online how to check a typical IACV by unscrewing the 2 mounting bolt, keeping the wires plugged in, and turning the ignition to the on position. It said the plunger should move in or out, but mine never moved at all. Is this the proper test I should use on my rig?
Thanks, Jason
Old Jul 25, 2011 | 07:34 PM
Sounds like an IACV to me. They are pretty cheap.
Old Jul 25, 2011 | 08:41 PM
Jason428sc's Avatar
IACV was the problem. The screw mechanism that makes the plunger move back and forth was locked up. I got it freed it up and it idles smooth now.
wick_60010
Nov 22, 2017 04:25 AM
KGN96discoSE7
Sep 23, 2017 07:23 AM
JStephen
Feb 2, 2010 06:59 PM
westernsun
May 27, 2006 04:24 PM
